Remove zoom/pan from undo/redo history
Message 1 of 38
I know there is no way to exclude zoom and pan from the history, so I'll make a post on the forum hoping to get consent on this honestly unnecessary and harming feature. We should decide nonetheless whether to include them or not. I'm a Fusion 360 user and when I learnt about this I was so let down on the software, why in the world is this a thing and who thought it was a good idea?
Please tell me if you know a way to exclude them. I'll highly appreciate.
Accepted solutions (3)
Replies (37)
Message 2 of 38
Kent1Cooper
Do a Search -- this topic has been raised many times before.
Kent Cooper, AIA
Message 3 of 38
imadHabash
i suggest to try UNDO >> Control >> Combine . Combine option Controls whether multiple, consecutive zoom and pan commands are combined as a single operation for undo and redo operations. also you can check and change UNDOCTL system variable with this values :
  • 0 UNDO is turned off
  • 1 UNDO is turned on
  • 2 Only one command can be undone
  • 4 Auto is turned on
  • 8 A group is currently active
  • 16 Zoom and pan operations are grouped as a single action
  • 32 Layer property operations are grouped as a single action
Imad Habash
Message 4 of 38
Yet Autodesk refuses to acknowledge this incredibly silly implementation. It needs to change, and complaint can only help.
Message 5 of 38
I've only found "Combine zoom and pan commands" in "User preferences -> Undo/Redo" which is on by default, and it doesn't address the problem. I can't find what you mean but it wouldn't help.
Message 6 of 38
cadffm
"it doesn't address the problem"
It DOES adress tge problem!
But it is also the limitation: You can combine multiple in line following zoom&pan steps to one undo step,
but you can not fully disable it.
. "I can't find what you mean but it wouldn't help."
Type in
UNDO<hit ENTER>
press [F1]
It apprears the Undo command documentation.
Sebastian
Message 7 of 38
pendean
Community Legend
Community Legend
BTW, you can tell Autodesk all about it here https://www.autodesk.com/company/contact-us/product-feedback
Message 8 of 38
a.henry.rose
this is a terrible feature. autodesk, what the what?
Message 9 of 38
pendean
Community Legend
Community Legend
@a.henry.rose no one here is Autodesk, and if they are, they have nothing to do with the software product they are simply policing the forums for the most part.
If you want to share your thoughts with Autodesk you will have to do more here https://www.autodesk.com/company/contact-us/product-feedback
Message 10 of 38
RobDraw
One person's terrible feature is another's valued tool. Nothing like a visual to help you backtrack.
Rob
Message 11 of 38
david-terry
@RobDraw
While you're not wrong, that's also far from helping.
For those who find this 'feature' as troublesome as I do, just grouping the pans and zooms changes nothing.
Maybe you all just need an example to see WHY this is the worst:
1) I undo a bunch of work, minutes of work, to see one small thing, to identify one piece of text, to see where I had one line drawn that I had subsequently removed.
2) I copy or write down whatever info I needed.
3) WHOOPS!! I accidentally hit my mouse wheel when grabbing my mouse and it zoomed just one single notch AND NOW ALL OF MY RE-DO'S ARE GONE FOREVER AND I HAVE TO REDO EVERYTHTING I JUST UNDID.
Hopefully That clears things up, what that problem is and why it's a problem.
I would love an option, a checkbox, that says "ignore pans and zooms for undo/redo".
Message 12 of 38
pendean
Community Legend
Community Legend
@david.terryXZUHwrote:
>>>...I would love an option...<<<
Ask for it at the proper location, here https://www.autodesk.com/company/contact-us/product-feedback
Then convince a few 1000s of others to do the same. It could happen in 2-5-10-20 years if it is not in the works already for big reveal sooner.
In the meantime really get into customizing and using UNDO command fully with all of its sub-options, you can get close to avoiding many of the pitfalls of the default choices at the commandline https://www.cad-notes.com/using-autocad-undo-its-more-than-just-one-step-back/
HTH
Message 13 of 38
RobDraw
Suggesting alternative workflows is helping. You can choose to accept it or not. Continuing to complain about something that has been requested for decades puts it in the hands of Autodesk. I'm not sure that's helping much if at all. Neither is asking for change without fully exploring your opinions.
Good luck.
Rob
Message 14 of 38
engviles
best solution I found: I switched software and stopped using autocad for most of my services.
Message 15 of 38
RobDraw
Great solution for a perceived issue.
Rob
Message 16 of 38
tboehler
Maybe do a save prior to using the undo command?  One second of safety is worth several minutes of undo redo's.
Message 17 of 38
pendean
Community Legend
Community Legend
@Anonymous Excellent tip if they know the differences between SAVE, SAVEAS and QSAVE in AutoCAD.
There is also the full abilities of UNDO that is often missed by an average AutoCAD user never goes beyond the default https://www.cad-notes.com/using-autocad-undo-its-more-than-just-one-step-back/ and https://www.cadlinecommunity.co.uk/hc/en-us/articles/360012754118-AutoCAD-Tip-Undo-Mark-Undo-Back plus https://www.google.com/search?q=autocad+undo+command+tutorial
Message 18 of 38
david-terry
Thank you for that suggestion @tboehler. Someone else recommended I dig into the various undo options (it never occured to me that undo would even have options, it's just undo, right?) and one of them allows you to save a current state. Next time I need to do a lot of undoing I'll try this out, but honestly I don't see  it being much faster than just saving a copy to work in or pull from.
I still just think that saving zooms/pans is redundant. Zoom to where you were when an actual command was issued, no need to save individual zoom points without a command associated with them.
Message 19 of 38
RobDraw
From this non-programmer/long time user's point of view, you're talking about stuff that may seem like it would be easy to change but just might require a lot of other changes and reprogramming. I'm pretty sure rewriting basic functionality from the ground up is not something that you want to do on such an old program.
Just saying...
Rob
Message 20 of 38
Kent1Cooper
As they said in the old spaghetti sauce commercial, "It's in there!":
Kent Cooper, AIA
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
