region objects disappeared
elaM747X
Message 1 of 17
elaM747X
Hi, I use AutoCad 2023, Windows 10. In my 2D project I imported small regions objects (detail parts) from others and after few days objects disappeared. Layer in on. I opened .bak file and these objects disappeared too. Please, help me. Ela
Replies (16)
Message 2 of 17
TheCADnoob
are they proxy objects? if so what is your PROXYGRAPHICS system variable set to?
CADnoob
Message 3 of 17
imadHabash
>> ..and after few days objects disappeared.
You may need to change your visual style .
Imad Habash
Message 4 of 17
elaM747X
PROXYGRAPHICS <1> doesn't work.
My computer system is:
Device name NG-LT-06
Full device name NG-LT-06.remartinson.local
Processor 11th Gen Intel(R) Core(TM) i7-11850H @ 2.50GHz 2.50 GHz
Installed RAM 32.0 GB (31.2 GB usable)
Device ID 566FA291-AD44-410F-920A-115D97FC6265
Product ID 00330-54339-14509-AAOEM
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
Message 5 of 17
pendean
Community Legend
Community Legend
Share actual source and final files please.
Message 6 of 17
elaM747X
Doesn't help me.
Message 7 of 17
elaM747X
I changed visual style (I tried different) but these regions objects still invisible.
Message 8 of 17
elaM747X
https://app.box.com/s/n44dsnykskik20svjih0swkqoxyxyt16   - MY NEW FILE
https://app.box.com/s/5vf5sbvc7ctr8qgeqhkr4s98sdgbpnmh - the one of original files that I copied in my drawings.
Thank you for helping me.
Ela
Message 9 of 17
TheCADnoob
I have tried to duplicate the issue but have been unable to.
CADnoob
Message 10 of 17
elaM747X
Probably author of drawings that I copy some parts, used AUTOLIPS programing his file to disappeared after some action in another and my file.
Message 11 of 17
cadffm
No, something like that is impossible.
The only thing we see is: There are noe regions.. like the User erased them, nothing else.
In your .bak File the regions are missing too?
That means nothing other than that the regions were already missing when you saved before last.
(AutoCAD does NOT change a .bak file. They are only overwritten when saving with the latest version)
DWG file: State of the last save
BAK file: State of the pre-last save
Sebastian
Message 12 of 17
Kent1Cooper
@elaM747X wrote:
... I imported small regions objects (detail parts) from others and after few days objects disappeared. ....
How did you "import" them?  There's no Block in your drawing with the name of theirs, so I assume you didn't just INSERT that.
Also, can you narrow down your drawing to just the area where the Regions from theirs should be?  I find there are 263 Regions in theirs, and 10,536 in yours, so it's hard to know where to look for whether some of those are the same as theirs.
Kent Cooper, AIA
Message 13 of 17
Kent1Cooper
@cadffm wrote:
.... The only thing we see is: There are noe regions.. ....
Not for me [see the numbers in my previous Reply].
Kent Cooper, AIA
Message 14 of 17
cadffm
😄 NO regions at the place where he is missing them...
Sebastian
Message 15 of 17
elaM747X
    Above there is a narrow of my drawing. I use copy and paste these regions objects from file (link below) to my file (link above)
Thank you.
Ela
Message 16 of 17
cadffm
As you wrote before too (with links to another version of your both files).
And it worked, right?
You can copy&paste objects, incl. the REGIONs, right?
And from then, there is no reason why the regions should went,
except an user initiated action or corrupt data - what Acad tried to fix by recover-process,
anything else is out of my knowledge.
Sebastian
Message 17 of 17
elaM747X
Thank you.
I may copy paste regions but if I move region in my drawings or change layer or want convert to block, regions disappeared.
Ela
