Reduce File Size
Reduce File Size
casey.oconnorKFGAQ
Reduce File Size
casey.oconnorKFGAQ
We have been working with a very large STP file in our Plant 3D model, slowly. Drawing production is at a standstill due to this piece of equipment. I have tried every trick on the internet.
purge
-purge, r, no
-purge, r, a
overkill
wblock
block
explode
saving down to 2013
saving up to 2018
slicing the equipment shape into smaller segments
I have never been able to reduce the size below 35,000 KB.
While in the purge GUI, I found that shape I need (which looks to be the whole equipment) claims to be 3570.306 KB. How is this possible? How do I retrieve this smaller, imbedded block? I've tried inserting just that block and is still comes out to be 40,000 KB.
PLEASE HELP!
Alfred.NESWADBA
if you show the dwg-file we might find the nested block/block-definition.
Without the dwg-file how should we be able to find it?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
casey.oconnorKFGAQ
Alfred,
I don't think our client would be too keen on releasing a detailed equipment model to the internet. I', sure my employer would have more than a wrist slap for doing so.
Having said that, I'm interested to know your workflow in determining "finding the nested block/definition."
Thanks for your help.
Alfred.NESWADBA
Writing a small tool to find the block-in-block referencing.
- alfred -
Alfred NESWADBA
pendean
Community Legend
Community Legend
>>>...How do I retrieve this smaller, imbedded block?...<<<
Start INSERT command (or CLASSICINSERT in modern versions) to place a copy of the block "somewhere else" then BEDIT it to either simplify to remove much of its content). Now you can ERASE your extra copy of it.
HTH
GrantsPirate
If you have access to Inventor maybe reduce the shrinkwrap size following these suggestions.
https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/Shrin...
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
I avoid using detailed design models in AutoCAD products, whether it's Plant3D, CADWorx, or AutoPLANT.  There's far more detail there than is necessary to get the job done, which results in massive file sizes.
There is little to be done to reduce the file size when dealing with highly detailed imported models; instead, if you need to flatten or otherwise include the objects in generated drawings, spend 15-30 minutes with some boxes and cylinders to make a simplified generic (and very lightweight) version.  If you are only using the model to reference nozzle locations, door swings, and other physical positions then use Navisworks Simulate or Manage to publish an NWD and reference that inside AutoCAD.
