Recreate an exploded spline
mariandrealopezc
mariandrealopezc
Hello! I honestly don't believe this is possible but better safe than sorry:
I exploded a very complex spline, which, not surprisingly, resulted in thousands of nodes that i joined into a polyline
I was fine with it since it was just a drawing but now i need to make an array around this path and i believe it's not working because the segments are too short.
Is there a way to recreate or smooth this polyline into a spline again?
Patchy
You can get it back very close to the original with help from PLDIET.LSP
Kent1Cooper
How do you Explode a Spline?  When I try, I get this message:
Cannot explode SPLINE
and there's no Explode option in SPLINEDIT.  Are you talking about the convert-it-to-a-Polyline option?
Kent Cooper, AIA
mariandrealopezc
You're right, i converted into a polyline and then exploded it
