Design accessibility
richfemelectrics
richfemelectrics
Greetings to you great people. I would please like to know the best way to store designs in such a way that even if the system used to carryout the design gets lost, or damaged or in other words, is it possible to login with my Autodesk ID and detains and accesss my AutoCAD designs in another system different from the system where my designs are stored?
Thank you in anticipation of your quick, positive and productive response.
richfemelectrics
Note: This post also applies to AutoCAD Electrical and AutoCAD MEP
richfemelectrics
paullimapa
Your design dwg files if accessed from any of the available internet cloud services should also be backed up somewhere else by you. You’re responsible for these files and no one else
Paul Li
IT Specialist
@The Office
Valentin_CAD
@richfemelectrics ,
@richfemelectrics wrote:
... is it possible to - access my AutoCAD designs in another system different from the system where my designs are stored?
Yes.  Consider the suggestion from @Kent1Cooper :
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
