REC DUCT LENTH TAGS
REC DUCT LENTH TAGS
asherjoh
Message 1 of 13
REC DUCT LENTH TAGS
asherjoh
Is there a way to set up text for rectangular duct throat lengths and radius elbows rather than having to manually input them?
Replies (12)
Message 2 of 13
wispoxy
Use a mix of DIMSTYLE and ENHANCED ATTRIBUTES in a block. Sometimes I layout ducts for monitoring systems because of airflow, but I do it in 2D. If you want a sample of how I do it, I can extract a small sample for you 🙂
Message 3 of 13
BeKirra
It looks likely you are not using any ducting add-on.
Theoretically speaking, there are 2 ways to get text/size of throat:
1) Measure the line lengths on an existing duct object then place text that matching what you got;
2) Draw new duct piece then obtain the throat size from your input of the duct.
If I understand your question correctly, you are after the 1st option.
Here is an example:
(defun c:DuctThroat (/ ThroatLine1 Ent01 ThroatLine1_1stPt ThroatLine1_2ndPt Throat1
ThroatLine2 Ent02 ThroatLine2_1stPt ThroatLine2_2ndPt Throat2 PlaceText)
(setq ThroatLine1 (car (entsel "\nSelect 1st line: ")))
(setq Ent01 (entget ThroatLine1))
(setq ThroatLine1_1stPt (cdr (assoc 10 Ent01)))
(setq ThroatLine1_2ndPt (cdr (assoc 11 Ent01)))
(setq Throat1 (distance ThroatLine1_1stPt ThroatLine1_2ndPt))
(setq ThroatLine2 (car (entsel "\nSelect 2nd line: ")))
(setq Ent02 (entget ThroatLine1))
(setq ThroatLine2_1stPt (cdr (assoc 10 Ent02)))
(setq ThroatLine2_2ndPt (cdr (assoc 11 Ent02)))
(setq Throat2 (distance ThroatLine2_1stPt ThroatLine2_2ndPt))
(setq PlaceText (getpoint "\nInsert throat size: "))
(command "._text" PlaceText "" "" (strcat (rtos Throat1 2 0) "x" (rtos Throat2 2 0)))
(princ)
); end of defun
Note: This code measures lines only, not polylines.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
Message 4 of 13
asherjoh
Sure, can I see an example?
Message 5 of 13
asherjoh
How do I use the code you show? I tried imputing it in the AC command line but it gave error replys.
Message 6 of 13
BeKirra
1) Copy my code to NotePad then save it as ThroatSize.lsp
2) Move this file to
    C:\USERS\YourName\APPDATA\ROAMING\AUTODESK\AUTOCAD MECHANICAL 2014\R19.1\ENU\ACADM
    (Note: Your AutoCAD version may be different to mine but the path should be very similar.)
3) In AutoCAD Click "Load Application..." under "Tools" tab (or type _appload in command line), after Selecting ThroatSize.lsp then click "Load" button then "Close".
4) Now you are ready to use the code - type DuctThroat (not case sensitive) in the command line then click your "Enter" key.
5) Follow the instructions showed in the command line - you should be fine.
HTH
X² + Y² = C²
Message 7 of 13
asherjoh
Thank You
Message 8 of 13
asherjoh
I can't get past this point.
Message 9 of 13
BeKirra
Drop the file to the "support" folder showed on your screenshot.
HTH
X² + Y² = C²
Message 10 of 13
asherjoh
I loaded and used it but it could be a conflict of versions. Here is what it said.
Message 11 of 13
asherjoh
When I use it on a 2d line it works but it does not seem to work on my 3d duct.
Message 12 of 13
BeKirra
Sorry, based on your original question I thought it was a 2d object.
3d drawing would be a different story.
X² + Y² = C²
Message 13 of 13
asherjoh
Sorry I was not clear. I could use something like that. I really don't know why it does not have it. It is a common requirement in ductwork construction. I do thank you for your effort. Sent from my Verizon Wireless 4G LTE smartphone
