AutoCAD Forum
Retain Viewport override layer state when Bind
8 REPLIES 8
Message 1 of 9
Baker_ADG
868 Views, 8 Replies
I cannot beleive i have not been able to find a topic on this.
I have a drawing with several viewport overrides to an xref in multiple viewports.
How can i bind the xref and maintain the overrides? bind vs. insert?
Visretain is set to 1.
Jon Baker | Land Development & Infrastructure Design Manager
Alignment Design Group | Denver | Colorado
Civil 3D 2021 | Windows 10
8 REPLIES 8
Message 2 of 9
wispoxy
in reply to: Baker_ADG
Don't use insert. Use bind then explode.
Message 3 of 9
drjohn
in reply to: wispoxy
Then you will have a bunch of layers called [filename]$0$[layername]
Really messes up the layers.
Regard,
DJ
Message 4 of 9
Baker_ADG
in reply to: drjohn
yeah.. so.. still no answer? lol. i know its friday!! 😉
Message 5 of 9
3wood
I agree with wisp. No insert, only Bind works for this scenario.
Message 6 of 9
There's an old lisp routine that will rename all the $0$ table names..give this a try after you bind an xref:
https://github.com/aaronlance/CodeSamples/blob/master/LCT/fixbind.lsp
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Message 7 of 9
GrantsPirate
I just tested it with insert and it worked fine, kept the overrides, no long layer names.  2016.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 8 of 9
Baker_ADG
in reply to: GrantsPirate
thanks guys, i'll give it a try today!
Message 9 of 9
kzalec
The link you provided doesn't work for me.  It says "page not found".
AutoCAD Inside the Factory
