Re: Plotting Bearing Points
lysaghtassoc
lysaghtassoc
Hello Everyone!
Please help me, as I've been scratching my head for a couple days on this..
I am trying to plot a site plan using bearing points - some of the bearings seem to work, however when I get to (for example) @41360<S234d10'00"W it will not work! I'm wondering whether the degrees is too large? If it is, how do I go about doing this?
I have attached a picture of the LOT that I am trying to draw, along with the bearings and distances.
I have got them down as (But maybe this is where I'm going wrong!):
A-B N54d10'30"E (54700mm)
B-C S144d09'00"E (41360mm)
C-D S234d10'00"W (60670mm)
D-E N324d06'30"W (35360mm)
E-A N9d06'30"E (8480mm)
Kind regards,
Jane
Patchy
This is not bearing, this is azimuth.
Every angle is measured from North and goes clockwise, then go to the next line
(Shown in Red)
But when you rotate a line, autocad uses negative.
lysaghtassoc
Thank you very much! Had to look up the difference. For some reason it also helped to turn the starting point from North to West.
