Buenas tardes Estimados,
Tengo una PC con AutoCad pero necesito formatear y volver a instalar el AutoCad..se puede utilizar la misma licencia?
Solved by john.vellek. Go to Solution.
Hello @Anonymous,
Yes, you should be able to use the same license on the same workstation. I suggest that you consider using the License Transfer Utility
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
