random error lines
random error lines
random error lines
i am using autocad 14 and while working my screen suddenly shows multiple small lines attached to my drawing. I am not able to select these lines and the disappear if i restart my laptop 3-4 times. Regen also dosen't work
wispoxy
Please share a screenshot, thanks.
Alfred.NESWADBA
Does the same happen when you disable the hardware acceleration?
Does that happen only in one drawing? In that case you can try
  • run command _AUDIT and see if there exist errors in the drawings database (and clean them)
  • run copy & paste to copy your geometry into a new drawing and continue to work with that drawing.
A screenshot would be great, of course!
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
wispoxy
Can someone please explain what AutoCAD 14 means, usually people give me a year, thanks.
