We have a new amazing multileader that uses a block with attributes to label our drawings. The attributes are found in the key (callout) of the block, and the name of the item I'm labelling. In my site plan, I want to show the name of the item, but not the key. Before we developed this great multileader, we were just using mtext to name the items.
ATTMODE cannot = 0 because there are some attributes I need to see.
ATTDISP doesn't help either
No amount of layer override (freezing, turning off, setting colour to 255,255,255, setting to not plotable) is working!
The stuff I want to turn off, the key/callout, is on it's own layer - so turning it off should be easy! Other items on the layer are turning off and functioning fine normally.
It seems like attributes in xrefs are completely uneffected by layer management! In the base drawing, the attributes behave in the expected way with layer management.
