"UNDO" command does not work but shows actions in commandline
domiengoffin1
Observer Observer
domiengoffin1
Observer
Observer
Hi there,
Since a couple of days the undo command in AutoCAD does not work like before.
Now when I use the command the only changes I see are zoom-changes, things like drawing a line or erase won’t be undone. But in the command line AutoCAD tells me these things are being undone. (if you can still follow 😉 )
So I draw a polyline and a circle and then erase the line and zoom in on the circle. When I now use the undo command four times, the only thing changing is the zoom in on the circle. the line wont appear or disappear neither does the circle.
While the command line shows this:
Command: pl PLINE
Specify start point:
Current line-width is 0.0000
Specify next point or [Arc/Halfwidth/Length/Undo/Width]:
Specify next point or [Arc/Close/Halfwidth/Length/Undo/Width]: *Cancel*
Command: c CIRCLE
Specify center point for circle or [3P/2P/Ttr (tan tan radius)]:
Specify radius of circle or [Diameter] <8.9207>:
Command: e ERASE
Select objects: Specify opposite corner: 1 found
Select objects:
Command: U INTELLIZOOM
Command:  U
ERASE
Command:  U
CIRCLE
Command:  U
PLINE
I have triesd to play with the undo setting but no luck there.
Is there someone who can help me out?
thanks!
Valentin_CAD
@domiengoffin1 ,
Welcome to the AutoCAD forum!
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
