"Angled and Curved Lines Display Differently from Straight Lines in AutoCAD"
abeer737
abeer737
I'm experiencing an issue in AutoCAD where angled and curved lines appear lighter than straight 90-degree lines, even though they are all on the same layer, with the same line weight and properties. This problem persists in both model space and layout, and it seems to happen specifically with non-orthogonal lines (angled or curved). I've already checked the following:
  • Line weights are consistent across all lines.
  • All lines are on the same layer according to their layers.
  • I've used LTSCALE and REGEN to refresh the display.
  • Graphics settings like hardware acceleration and smooth line display have been adjusted.
This issue does not affect straight 90-degree lines, which appear correctly with the assigned weight. Could this be related to display settings or something else? Any suggestions would be appreciated!
pendean
Community Legend
Community Legend
@abeer737 wrote:
...Any suggestions would be appreciated!
Not seeing anything like that here
Have you installed the 2023.1.6 / 2024.1.5 / 2025.1 Update yet? You never quite state your year version, so that latest is what I listed. ABOUT command in your AutoCAD will confirm what you have installed. If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards.
If that did not help... Set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD 2023-24-25 that you have.
Also consider turning off LINESMOOTHING and LINEFADING variables: if still no relief then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices.
If all else fails, then turn off Hardware Acceleration as a last resort, if that totally fixes the issue then start a support ticket through your subscription portal as explained here
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-find-my-sup...
HTH
jreidKVSUZ
I just opened your drawing and on my screen all looks great.
Ran Audit and no errors.
Your XREFs did not show up but they are PNGs and should not affect the viewing.
But just in case, try this, XREF and UNLOAD the (2) XREFs
you have in your drawing and see if that does change your viewing.
If so, try using DRAWORDER on the XREFs and put them behind your lines.
Hope one of these helps!
JRR!
abeer737
The is occurring when I plot the file and export as pdf.
pendean
Community Legend
Community Legend
You opted to not save any plot parameters in your DWG file, and you never mentioned before now that those screenshots are from your PDF viewer.
Try changing your PDF viewer.
Try changing your PDF viewer display settings.
Try changing your plot scale and size. and pen settings (plot style table? LWEIGHT?)
Try changing your PDF driver. And it's output settings.
Or is it your monitor?
Some lines will always look a little jagged on a screen, this is not paper printing.
jreidKVSUZ
I just installed AutoCAD 2026 and I have the same issue of ARCs and Slanted lines not showing like Straight Lines do.
So I Googled and forgot I also commented on this request as well as Mr. Pendean.
Using what Mr. Pendean suggested, I checked the Settings inside Adobe Pro.
I also asked AI what the best display settings are for Adobe Pro for AutoCAD created PDF files.
They suggested to TURN OFF : Smooth Line Art and Enhanced Thin Lines
I did just that and wow.... I can now see all of my lines. They also said to have 110 pixels/inch (this is Adobe Pro's default setting)
I have Pasted this to here and maybe hard to see the lines showing up, but on my screen they pop out just line the straight lines do.
Hope this helps anyone having the same issues.
p.s. I added before about the settings for TRAYNOTIFIY Set this to 0.
With installing 2026, the default is to let you know you have plotted correctly. That pop up had to go away!
Thanks, JRR.
