Please add DXF as an option to the export command
steven_dusek
Message 1 of 11
steven_dusek
I create a lot of parts to be run on a cnc router. As things are set up now I have export the individual parts as a dwg. then save them as a dxf. It would be very helpful to export them directly as a dxf. If this is an option already, please tell me where I can find it.
Replies (10)
Message 2 of 11
DGCSCAD
Try the DXFOUT command.
AutoCad 2018 (full)
Win 11 Pro
Message 3 of 11
ChicagoLooper
Hi @steven_dusek
You don't need to export. You can use SAVEAS command.
The save as command will provide the option to save your dwg file to dxf format.
Chicagolooper
Message 4 of 11
CGBenner
@steven_dusek
Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
Message 5 of 11
steven_dusek
I do know about save as dxf. the advantage of Export is you can Export a selection from a drawing file. I create multiple CNC patterns in a single file. Currently I have to Export the individual patterns as a DWG. Then save those multiple dwgs and dxf files. It would be much easier to Export the patterns directly to dxf.
Message 6 of 11
DGCSCAD
Use the WBlock command and change the output to DXF.
AutoCad 2018 (full)
Win 11 Pro
Message 7 of 11
pendean
Community Legend
Community Legend
@steven_dusek What you want is not available, and you can't make it show up, but you can open a support ticket and ask for it then in 2-3-5-10-20years from now it might appear. Might.
In the meantime... you can customize with LISP or other programming language to create the interface and settings you prefer if the other tips offered are not to your liking. Let everyone here know how you would like to proceed for additional guidance.
Message 8 of 11
DGCSCAD
It's absolutely possible:
AutoCad 2018 (full)
Win 11 Pro
Message 9 of 11
pendean
Community Legend
Community Legend
I'll assume you are simply missed the OP only wants DXF out ability inside EXPORT command, nothing more, and I directed them to explore your tip and others too.
Message 10 of 11
DGCSCAD
One way to 'export' to DXF is to use the Wblock command.
I'm assuming that would meet the OP's needs.
AutoCad 2018 (full)
Win 11 Pro
Message 11 of 11
steven_dusek
That is brilliant. Thank you. I never thought of using wblock in that way.
