I was wondering if it is possible when drawing a straight line in AutoCAD that if the lines crosses other lines. It makes an arch over the other line. Like in this screenshot.
I need to do it now by hand. Draw a line to a certain distance from the line then add a 180 degree arch and draw the line further straight.
Solved by ennujozlagam. Go to Solution.
hello, i don't think it's possible you still need to draw arc line or draw a pline > first point to second point > arch > s > pick point > point > L . thanks
hello, please see screencast below. thanks
