I have a block that I cannot purge. In trying to figure out why I have considered
"It is nested inside another block" - I have purged all other blocks from the DWG leaving only the one I am having trouble with, it still will not purge.
"It is inserted in the drawing" - I have used ctrl+A to select all and delete, in both paperspace and model space, I have ensured all layers are unfrozen, I have purged all layers, etc.
"It is an attached xref drawing" - I have used EXTERNALREFERECENS to bring up the browser, the file I am working with is the only one displayed.
Any other options? I can insert the block, it's just a triangle. I've tried inserting it, selecting similar and deleting, Ive tried editing the block in the block editor, changing it to something else, inserting and deleting it from the drawing, etc. I'm trying to create a template, so I would really rather not propagate this through every drawing I make from here after. Thanks
