Publishing problems
Publishing problems
2204008HBM8M
Message 1 of 17
Publishing problems
2204008HBM8M
Centerline shows as it should in the model tab but in the layout tab, it shows as a continuous line and plots and publishes as a continuous line
Replies (16)
Message 2 of 17
imadHabash
Try to check PSLTSCALE (System Variable)
Imad Habash
Message 3 of 17
2204008HBM8M
It is 1.
Message 4 of 17
pendean
Community Legend
Community Legend
@2204008HBM8M wrote:
It is 1.
change it then REGENALL would be the next step to try after only just checking.
Also, what are your settings for LTSCALE and MSLTSCALE too please?
Message 5 of 17
imadHabash
can we have a CAD dwg sample please for testing?
Imad Habash
Message 6 of 17
imadHabash
Imad Habash
Message 7 of 17
2204008HBM8M
I have attached the file. You can check it now.
Message 8 of 17
2204008HBM8M
Both of them are 1 and REGENALL did not solve the problem.
Message 9 of 17
wispoxy
/Go to your layout
/Lock viewport and go inside of it
/Use command PSLTSCALE
/Use REGEN while in viewport
/Exit viewport and REGEN again while on your layout
/Switch tabs and return to the tab
.//If modelspace is 1:1 and layout viewport is 1:1 it should work.
.//If modelspace is 1:1 and layout viewport is 1'=1/8"-0' keep in mind of your line pattern scales. You need to enlarge or make the linescale 0.0015 or 48 or 96. When I say "enlarge" I'm specifically talking about the linepattern not the object itself "Linetype Scale" in properties of the line. You may need to play around with show annotations too.
Message 10 of 17
2204008HBM8M
Did not work.
Message 11 of 17
CodeDing
@2204008HBM8M ,
When you're in Model Space, See how your scale is set to 1:1?
Then, when you go to your Paper Space and enter your Viewport, See how your scale is set to something else?
...That is your problem. To fix it, do the following:
1) Set the scale inside your viewport to: 1/4" = 1'-0" (then, lock your viewport)
2) Then, go back to Model Space and set your scale to the same thing (1/4" = 1'-0")
3) Then run the REGEN command
4) Then, adjust your LineType Scale(s) to their appropriate sizes. I changed your centerlines to 0.2.
Best,
~DD
Message 12 of 17
2204008HBM8M
Perfectly solved. Thank you very much.
Message 13 of 17
wispoxy
I got a feeling something is being represented to us incorrectly. You said "centerline", that term means a specific pattern + line + purpose. Are you not talking about a pattern, line, and purpose? Please describe "Centerline", you're not using the word "the" before saying "Centerline" so I assume we're thinking of it differently.
Message 14 of 17
wispoxy
He showed you exactly by image what I typed out, and you said mine didn't resolve the problem. 🤣
Message 15 of 17
2204008HBM8M
I was accessing this page using my laptop then and it didn't show the lines beneath the "return to the tab" line. Now I am checking it from my phone and the rest of the instructions are showing here.
Message 16 of 17
2204008HBM8M
Yes, I should have put that "the" there. Sorry for my mistake. English is not my native language, so I missed it.
Message 17 of 17
wispoxy
I wasn't picking on your language because it works both ways. When you said what I listed didn't work I re-read your original post and noticed it without the word "the" at the start, so I started thinking you were talking about another object or block named "Centerline" and not the actual centerline pattern or feature. All good!
