I am having a problem, while publish the whole project drawings (160 Sheets) to PDF.
While publishing to PDF, my all cover sheets of the drawings are half offset in the paper. I changed the X,Y,Z to Zero, then 98% of the template comes in to the paper space.
But still bottom and right side template border lines are out of the paper while publish. I also checked the margin space, all the values are zero. It looks small issue, but some where i did the mistake, kindly please do advise the solution.
I am here by attached the sample output of the PDF.
There may be "objects" off to the left.
Do you plot extents?
What's different about the cover sheets from the rest? Try copying the guts of a cover wheet to a copy of the sheets that work.
Is the title "block" identical to the other sheets that print ok?
All of the above I have run into.
How about sheet size?
R
Yes i plot with extents. When i check preview its correct in the center, but while i publish with other sheets, some of the cover sheet cut in left side and some of the sheets in right side.
Except cover sheet, all sheets are in center and plotted correctly. The title block (Cover sheet) is different from the other drawing sheets. Not sure where i missed out.
