Project based ACAD template
ian
Message 1 of 16
ian
Hi All
Background
I want to use ACAD so that I have 1 x DWG for plans, section elevations.  Plus another DWG file the sheets.  but within the Sheets file, I will only have 1 x model space and 1 x layout.
The setup
I have a master ACAD DWT file that is located on a central server i.e. Z drive  A user profile points to this DWT file.  Within the DWT i have setup the CAD Standards etc.
This DWT hosts 1 x model space and 1 x empty layout, any new DWG will match the DWT
What I am trying to work out is.
I want to have a 2nd DWT located in the project folder, which will host the various titleblocks.  Thus, when a new project starts, I edit this project DWT and its titleblocks to suit the project.
The workflow would be.  create a new DWG using the central DWT, then use the 'add layout from template' and select the sheet ie A1L from the project folder DWT.
I was thinking of having an ACAD use profile per Project, but a user will not swap profiles.
I want to know how I can make ACAD point to the Project DWT for the sheets/titleblocks.?
Replies (15)
Message 2 of 16
tramber
The Design Center (CTRL+2 from the alpha keyboard) can be smart to import almost anything from favorites... so it does to any open dwg or dwt
Message 3 of 16
ian
Hi Tramber
Can I add a link to a template in this?
Message 4 of 16
paullimapa
You can have multiple template paths by creating shortcuts to each of the project template folder location and save these shortcuts in the default Autocad template folder location (Or inside a subfolder)
Paul Li
IT Specialist
@The Office
Message 5 of 16
ian
What file are these shortcuts saved too and can the path be configured?
Message 6 of 16
ian
I can see that they het added to a registry called 'AllAnavDialogs'  but do they also get added to a file, so I can port the to other PCs
Message 7 of 16
paullimapa
The shortcuts should be directed to each of the project folder where you have your project template saved.
Here is an example of a Project Templates folder located under the default AutoCAD Template folder location
Note Shortcuts like 2026 VP Line Type when selected will go directly to the project template folder located under H: drive
Paul Li
IT Specialist
@The Office
Message 8 of 16
pendean
Community Legend
Community Legend
@ian Are you trying to use this feature/ability
Message 9 of 16
ian
Are you added these shortcuts to this dialog?
Message 10 of 16
ian
or is there a better option?
Message 11 of 16
paullimapa
Yes they will show up there similar to the screenshots I shared showing windows explorer
Paul Li
IT Specialist
@The Office
Message 12 of 16
ian
I have setup the main template to be defined by the options as per your image.  But i am trying to work out the best way to have a project based template as well.
  • Main template has all the CAD standards
  • Project template has the title blocks
Message 13 of 16
paullimapa
Unfortunately you can only select a Template (dwt) to apply to a dwg when you execute the NEW command.
Paul Li
IT Specialist
@The Office
Message 14 of 16
paullimapa
This is how they show up when creating shorcuts:
Paul Li
IT Specialist
@The Office
Message 15 of 16
ian
Morning Paul
Thank you for the replies.  So basically, you can only have 1 template defined.  Then use shortcuts to point to project specific templates.  Although this is not ideal, due to the huge number of projects, it is a work around.
Thank you
Ian
Message 16 of 16
paullimapa
You are welcome…cheers!!!
Paul Li
IT Specialist
@The Office
