Program to erase bak files?
MRM4TN
Message 1 of 12
MRM4TN
I'm looking for a good program that will automatically erase old bak files. I have one called AutoErase, but I can't get it to work on any machine. It used to work great. I could set it for which directories I want, files other than .bak files, and more. I'd like to find something similar to that. Thanks.
Replies (11)
Message 2 of 12
peterm
I just use Windows File Explorer and do a search for *.bak, then delete them.
Message 3 of 12
qnologi
This back and forth seemed worth reading... unless you already have.
https://forums.autodesk.com/t5/autocad-2000-2000i-2002-archive/are-bak-files-necessary-after-a-drawi...
qnologi
Message 4 of 12
TerryDotson
 As mentioned, Windows Explorer can find and delete all BAK files in bulk, so can the Windows CMD console.  If you were to consider third party software, DotSoft's ToolPac contains a more selective BAK purge that can search a drive/folders and shows the current drawings and their bak files (with previews) and time/size differences to help make more careful deletions.
tpdwgpurbak
Message 5 of 12
murray-clack
Have you looked into the MOVEBAK command?
Message 6 of 12
qnologi
It was briefly, or somewhat mentioned in my post. : )
qnologi
Message 7 of 12
MRM4TN
I could use Windows Explorer, but we have mutiple drawing directories and I like to keep .bak files that are up to 2 weeks old, just in case.
Message 8 of 12
peterm
In which case, you just do a search from the root directory, then order the bak files by date and delete all the ones older than 2 weeks.
Message 9 of 12
leothebuilder
I use the MOVEBAK command (Express Tools) to divert all the .bak files to a specific
folder on my C-drive called (you guessed it) "Bakfiles".
From there it's very simply to delete older files no longer needed.
Message 10 of 12
Ed__Jobe
I use the MOVEBAK command. Then I have this .NET dll that deletes bak files from the movebak folder which are older than 30 days. It runs when you close acad. You don't have to do anything. The included script will NETLOAD it for you.
Ed
How to post your code.
Message 11 of 12
josue777torsan
How do you load dll file?
Architect, CAD Manager in Mexico City
Message 12 of 12
ennujozlagam
you can refer to this ARTICLE and see if helps. thanks
