I need to revolutionize a closed
figure (POLYLINE) around an axis.
I have already revolutionized similar
figures without any problem and then
converted to 3D Solid.
What happens when revolutionizing the
figure in question is that it takes a
longer process time than usual, up to
25 minutes, and the result is a
revolution surface with blurred
details and the absence of a "hole"
or "emptying" where it should have
been. Can you help me?
Thank you so much!!
Solved by Patchy. Go to Solution.
