I accidentally performed the NAVSWHEEL command, which turned the background from black to gray, and made it so that there are other pop-ups as well while I'm working. UNDO did not fix the problem, and I tried to play around with a few things in the NAVSWHEEL command, but was not able to fix it. Does anyone know how I can undo whatever I did, so that the background is not gray, but black, and that the new pop-ups don't show up?
Thank you
Solved by paullimapa. Go to Solution.
Solved by cadffm. Go to Solution.
what pop-ups? Share screenshots to show what you are talking about.
Background: I guess your "issue" is a changed visual style, but I am not sure because of less informations (your .dwg would show us all file related settings)
Type in:
SHADMODE<enterhit>
Look for the <current visual style> and change it to 2D.
Was it your problem?
If not:
UCS<enter><world>
PLAN<enter><world>
and now?
Otherwise, share screenshot and your file for a better understanding.
Sebastian
Try VSCurrent and enter 2dwire
Very good…cheers!!!
