Al copiar un objeto o elemento (línea, polilínea, bloque, etc) de un archivo a otro archivo lo pega con otra escala.
Verifique Insunit, dwgunits y están iguales en los dos archivos.
Solved by INKOIngenieria. Go to Solution.
Change Scale Factor in primary units
Jayhar.M.J
Jayhar.M.J
indicate the procedure please
Change the units in "Insertion scale" to match the units your drawing is in (as your initial post indicated a scale factor of 2540, is one of your drawings actually in inches?)
This variable is also controlled by command INSUNITS which you say you have already checked.
There seems to be some problem with copy/paste scales in AutoCAD version 2019.1.2, see this thread
Hi
Check Scale Factor in both cad files. Dimension Style Manager > Select current style > Modify > primary units > Scale Factor
Inches to Millimeters = 25.4
Inches to Centimeters = 2.54
Jayhar.M.J
Hi
Jayhar.M.J
SOLUTION
Verify the parameters in DGWUNITS are equal in the two files
Scale objects from other drawings upon insert? [Yes/No] --- NO
SOLUTION
