problem with x-ray visual style
Message 1 of 8
I have encountered a problem that I don't seem to fix. It concerns de x-ray visual style. Before it showed surfaces and lines in a an easy to read manner. It's a very informative mode. But for some reason, it shows all grainy now. It does so in all my files. Is it some sort of setting that I am missing here?
See these posts depicting the smooth 'before the problem' x-ray mode and the grainy image it produces now.
What could solve this issue?
Replies (7)
Message 2 of 8
Message 3 of 8
imadHabash
try to close your AutoCAD and reopen it again and see if any changes . if not fixed :
  • i suggest to review X-ray settings from VISUALSTYLES command .
  • reset AutoCAD to default settings . >> Click <<
Imad Habash
Message 4 of 8
Hi, thanks for your repsonse. I tried changing the visual style settings of x-ray already. It didn't work. Resetting to default seems a little extreme. It might work. But I might reset certain unwanted settings too. I'd prefer to avoid that.
Message 5 of 8
imadHabash
if you take the 3d model to a new CAD dwg , any changes ?
Imad Habash
Message 6 of 8
No, unfortunately that doesn't seem to solve it.
Message 7 of 8
imadHabash
toggling OFF / ON hardware acceleration from GRAPHICSCONFIG command , any changes ? 🙂
Imad Habash
Message 8 of 8
Excellent! that fixed it! My gratitude is enormous!
