Problem with plot two, overlapping viewports
robert_chmielewskiUMURG
Observer Observer
Observer
Observer
Hello everyone, I got a problem.
I need to cover a viewport 1 (all plan) with another viewport 2 (detail-circle viewport)
I used region and two viewports.
In plot preview it looks good
In plot is not OK
Why?
pendean
Community Legend
Community Legend
AutoCAD viewports don't work like that, never have. Sorry.
But you can fudge it occasionally if you turn off / uncheck PLOT PAPERSPACE LAST in your PLOT dialog box pop-up.
Observer
Observer
AutoCAD viewports  work like that, only circles not working with viewports well. All you need to do is replace the wheel with a poligon and it works. Why print preview work but the print dosen't?
check/uncheck PLOT PAPERSPACE LAST  of course don't work.
Maybe the problem is in the printer drivers.
Thank you for your  tip
Valentin_CAD
@robert_chmielewskiUMURG ,
In your case, you may want to VPCLIP the viewport (see highlight below) around the circular viewport - created by using MVIEW - Object.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
