AutoCAD Forum
Problem with interface
4 REPLIES 4
563 Views, 4 Replies
I've recently installed a new version of autocad (2017), chenged interface to classic autocad (done it manually, by turing off ribbon tab and customizing toolbars , and then problem appeard). There is another possibility, that problem appeard after changing startup. Getting to point - when I started working and using pan or scroll drawning space started to shrink and to widen. It isn't a very big problem, but to be honest it make my work very irritaiting.
I do not know how to define this problem and find it in internet.
4 REPLIES 4
imadHabash
if you turn ON ribbon and fix your startup .... does it's fixed or what ? also if you check the box of the windows task bar Auto-hide the taskbar , any changes ?
Imad Habash
user181
Hi @Anonymous,  I have that problem when the coordinates are turned on. You can turn them off if you don't need them and the problem should stop. To turn them off click on the 3 bars in the lower right of the cad screen and uncheck the coordinates (see attached pic)
in reply to: user181
Thanks a lot!
user181
You're welcome
Forma Design Contest
