Problem with Graphics
Message 1 of 9
Hello everyone,
I have a serious problem with graphics in Autocad 2018. It happened a few days ago while ı was using 2015 version. So I deleted it and replaced with 2018 version but still, I have the same issue. Colors changed as seen in the images. It is solved when disabling the hardware acceleration but this time line command and cursor move very slowly. It is like I am drawing on a very old computer. I have a strong graphics card. Please help me with that.
Lenovo Thinkpad E560
Intel Core i7
AMD Radeon R7 M370
WHEN DISABLED MODE: COLORS OK BUT DEADLY SLOW.
Replies (8)
Message 2 of 9
cadffm
Strong, but is not working perfectly with Autocad.
Your Hardware is not certificated, right?
http://usa.autodesk.com/adsk/servlet/syscert?siteID=123112&id=18844534
Sebastian
Message 3 of 9
pendean
Community Legend
Community Legend
If the above tip for a certified or approved driver from Autodesk does not help, try your Lenovo and see if they have newer (or older) drivers that can help.
Message 4 of 9
chriscowgill7373
instead of shutting off Hardware acceleration, try shutting off each of the individual options until the problem is solved, and also at the same time make sure that AutoCAD is still functioning normal speedwise.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2024 on Windows 10
Message 5 of 9
Thanks for the reply. When hardware acceleration is enabled, I shut down each individual option but still, colors change in place of another.
Message 6 of 9
Thanks for the reply. No, it is not certificated. But with this laptop, I have been using AutoCAD for 10 months and never had a problem. I will try to install another version of graph card driver.
Message 7 of 9
braudpat
Hello
Have you tried to run with HQGEOM = 0 ?
Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 8 of 9
Yes I tried. Nothing has changed.
Message 9 of 9
cadffm
    mucahit.kucuk wrote:
    "It happened a few days ago"
This driver is 7/27/2017 (a few days ago)
https://forums.lenovo.com/t5/ThinkPad-11e-Windows-13-E-and/e460-AMD-Radeon-R7-graphics-card-issue/td...
    "I will try to install another version of graph card driver."
Do that, try some other(older) drivers
    "I have been using AutoCAD for 10 months"
On 2015 ok, but so it should been working in 2018 99% too.
Acad is using the AMD Radeon R7 M370?
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
https://forums.autodesk.com/t5/autocad-forum/autocad-2015-doesn-t-use-dedicated-graphics/td-p/526622...
https://forums.autodesk.com/t5/autocad-forum/autocad-2017-won-t-use-my-dedicated-graphic-card/td-p/6...
aso.
When using M370: Try your onboard chip, you should have an onboard Intel HD Graphics 520 chip.
(Radeon is much better, but it doesnt help when Problems appear with Acad - chatch the straw)
But at this Point I cannot help you, my english is too terribly. Sorry, I'm out of here.
Google for switch between M370 / HD520
https://www.google.com/search?q=switch+M370+HD+520&oq=switch+M370+HD+520
Sebastian
