Problem with graphics acceleration
Message 1 of 25
I am using a laptop which has an Intel HD graphics 5500 card and a NVIDIA Geforce 820M card. My AutoCAD is currently running on the Intel graphics card. Recently, my AutoCAD is unable to run on graphics acceleration. I am not sure why this is happening, but I hope someone has a solution to this problem
Replies (24)
Message 2 of 25
_gile
This forum is dedicated to the programming of AutoCAD with the .NET API.
You should ask your question on the General AutoCAD forum.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 3 of 25
Vinayv4v
Welcome to Autodesk Community Forums!
Please update your graphics driver to the latest version.
Take a look at the link:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-u...
Cheers,
Vinay Vijayakumaran
Message 4 of 25
Thanks for the reply.
I tried to follow the procedure in the link, but I am unable to find adaptive degradation dialog box.
I have attached a screenshot of my tuner log for more clarification
Message 5 of 25
Vinayv4v
Which Version of Autocad are you using?
Go to Options (op) > System > check if this is ticked.
Cheers,
Vinay Vijayakumaran
Message 6 of 25
I am using 2016 version ( student)
Message 7 of 25
Vinayv4v
Its the same for 2016. Have you checked if the automatic update is ticked in the options.
Cheers,
Vinay Vijayakumaran
Message 8 of 25
Yup
Message 9 of 25
After entering "3DCONFIG" FOLLOWED BY 'ENTER' I get this dialog box
Message 10 of 25
Vinayv4v
Turn on the Hardware accelaration from that menu.
If its is not turning on then
Command : OP> Enter> System > Turn on auto update as shown in the above post.
Cheers,
Vinay Vijayakumaran
Message 11 of 25
Vinayv4v
Is your Graphics driver up to date.
Check for the latest graphics drivers for NVIDIA
 http://www.nvidia.com/Download/index.aspx
Also check these articles:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Hardwa...
If still not working then try resetting the Autocad settings to default.
Cheers,
Vinay Vijayakumaran
Message 12 of 25
hi,
The AutoCAD software is running on Intel HD graphics 5500. But I have another graphics card on my system that is nivdia geforce 820M.
Message 13 of 25
Vinayv4v
Please go through this article
Issue:
On a system with integrated graphics (mostly laptops), your AutoCAD-based product uses the integrated graphics adapter instead of the advanced or discrete graphics card. (Autocad-2016)
Causes:
The technology for the dual video configuration is called "Optimus" by NVIDIA and "Enduro" or "Dynamic Switchable Graphics" by AMD. The problem occurs because the switching software chooses the wrong GPU for AutoCAD.
Solution:
To avoid this behaviour in AutoCAD 2016, apply Hotfix 4 that can be downloaded from the following link.
https://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/accumulated-hotfix-4...
Cheers,
Vinay Vijayakumaran
Message 14 of 25
Hi Vinay,
I have downloaded the hotfix, and now the software is running on Nvidia GeForce 820M. I have downloaded the latest driver from the Nvidia website, but AutoCAD still shows the same problem. I have added a screenshot of the problem.
Message 15 of 25
Vinayv4v
Hi saiabhishek,
Turn off your hardware acceleration. And check whether autocad is working fine?
Then make sure your auto update graphics driver is checked on in options.
Close and restart Autocad and check for any recent updates.
After the updates  you can turn on the Hardware accelaration after that.
Cheers,
Vinay Vijayakumaran
Message 16 of 25
AutoCAD works fine without the graphics acceleration. Then I ticked auto update graphics driver, then I reset AutoCAD to its default settings. But, now I am not sure on how to check if there are updates. Also, do you know which is better Intel HD graphics 5500 or Nvidia GeForce 820M?
Message 17 of 25
Alfred.NESWADBA
This looks like a memory (hardware) defect.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 18 of 25
john.vellek
Hi @Anonymous,
This does indeed look like a hardware issue of some sort. But, to follow through this thread, is DirectX being utilized when you look at the GRAPHICSCONFIG window?  If so, which version?
John Vellek
Message 19 of 25
Hi @john.vellek,
Yes, it is being utilized. AutoCAD is using DirectX11, but my computer shows that my computer runs on DirectX12. And if it is a hardware issue how do I fix it?
Message 20 of 25
Alfred.NESWADBA
Change the hardware ...
But to make sure you first can run some stress tests for both of your graphic cards, start with the
DXDIAG (from C:\Windows\System32)
and watch the reports as well as the screen while it runs some test on the display.
If that succeeds I would search in www for tools which tests system memory as well as memory on your graphic cards.
- alfred -
Alfred NESWADBA
