AutoCAD Forum
Problem with drawing
7 REPLIES 7
Message 1 of 8
rayHYSJJ
478 Views, 7 Replies
Hello
I have a problem with opening a drawing
can someone help or solve it please
Many thanks
7 REPLIES 7
Message 2 of 8
in reply to: rayHYSJJ
Welcome to Autodesk’s AutoCAD Forums.
after using RECOVER in AutoCAD 2016, I am able to open this file in AutoCAD. I also AUDIT and PURGE this file.
I even plot it to PDF. You will see Proxy dialog box while opening it. which you can choose "Do Not Show Proxy Graphics".
let me know if you are able to open and work on it. See attachment.
Karan
Message 3 of 8
rayHYSJJ
Hello thanks for the quick reply
I opened the file, draw a line, hit enter and the bottom ribbon disappeared
Message 4 of 8
pendean
bottom ribbon?
Message 5 of 8
rayHYSJJ
in reply to: pendean
When you open drawing there is (not sure what you call them) command buttons (e.g polar tracking, ortho mode) on the bottom of the drawing and when I move the drawing or press enter they disappear.
Message 6 of 8
pendean
Thanks: is your autocad version fully patched and updated? That sounds like a bigger problem than just a drawing file.
Message 7 of 8
rayHYSJJ
How do I do that
Message 8 of 8
rayHYSJJ
I looked at that, but opened a new drawing and this doesn't happen
State of Sustainability Webinar
AutoCAD Inside the Factory
