Good morning, I am using AutoCAD 17, each time I use the commands, Copy and Mirror, it takes 12 seconds to bring the computer back to operating mode. Using any other command, it only takes 1 to 2 seconds to come back to operating. Why do these two commands take so long? Can any one help?
Solved by john.vellek. Go to Solution.
Hi @Anonymous,
Is this lag happening in all Drawings or just specific ones?
Is it possible to attach a sample drawing for me to look at?
i wonder what happened if you start a new CAD drawing then see if the problem still exist?
Imad Habash
Good morning John,
Drawing is attached in 2017 AutoCAD, set up in Metric. Take a look and let me know what you think.
Thank you for your time and comments,
Randall C. Feist
[Feist Cabinets logo]
9930 Kent Street
Elk Grove, CA 95624
916.686.8230 916-686-6723 fax
www.feistcabinets.com
CA Lic. # 523030
Hi @Anonymous,
I don't see an attachment on your post. Can you send to me by email? I will add it to your post and take a look too.
Hi Randall.
I ran Autdit, Purge, -Purge>regapps, and finally -EXPORTTOAUTOCAD to create a new drawing. It seems to be behaving much better. Why don't you try these steps on your computer to see if it helps.
I have attached my new file here for you as well.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Good afternoon John,
Thank you for the help and suggestion, it seems to have fixed the problem. The commands are now as normal, just a split second. Thanks again!!
