AutoCAD Forum
problem with base tool
15 REPLIES 15
Message 1 of 16
lejochan
1065 Views, 15 Replies
when selecting the base tool in the create view panel, and choosing from model space. the command line must read, select object or [entire model]
but when i do it, it says inventor server failed to load. and then the command line says move object. this is a student file, but i have tried it by using my own created 3D drawing and it does the same. i have attatched screenshots
15 REPLIES 15
Message 2 of 16
TuncayBAKKAL01
in reply to: lejochan
Please check this link.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Viewba...
TuncayBAKKAL
AutoCAD Eğitmeni ve Danışmanı
AutoCAD ve Fusion 360 Görsel Eğitim
Fusion 360 Kitabı Çıktı!
http://www.tuncaybakkal.com
Instagram: @tuncay_bakkal
Forumlarımızda çözülen sorularınızı "ÇÖZÜM OLARAK KABUL ET" ("Accept as Solution") seçimiyle işaretlemeyi lütfen unutmayın.
Beğendiğiniz mesajları lütfen "Övgü Puanı" ("Kudos") ile ödüllendirin.
Message 3 of 16
lejochan
in reply to: TuncayBAKKAL01
can you please give me step by step instructions on how to check if the file is on the correct path. i have tried the exporttoautocad command. it did change the file name but stil gives me the same problem.
thank you
Message 4 of 16
TuncayBAKKAL01
Tell me please your AutoCAD version. (2013/2014/2015/2016?)
TuncayBAKKAL
Message 5 of 16
lejochan
hi i am using Autocad 2014. think it is a student version
Message 6 of 16
TuncayBAKKAL01
You can download after install all service pack and hotfix. I think solve your problem.
https://knowledge.autodesk.com/support/autocad/downloads?release=2014
TuncayBAKKAL
Message 7 of 16
lejochan
i tried both 32bit and 64 bit. gives errors. screen shots attatched
Message 8 of 16
TuncayBAKKAL01
I suggest, you download AutoCAD 2014 on http://students.autodesk.com/. Uninstall your AutoCAD and after reinstall.
TuncayBAKKAL
Message 9 of 16
Alfred.NESWADBA
Start your AutoCAD, start command _ABOUT and upload the screenshot from that dialog (mask the serial if there is one).
So we know what product you are using exactly.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 10 of 16
lejochan
in reply to: Alfred.NESWADBA
hi
i have also tried uninstalling and installing from http://students.autodesk.com/. it still does the same. i must write my exam in march hope you can help me please. here is the screenshot you requested
thank you
Message 11 of 16
Alfred.NESWADBA
are you working on Windows 10?
- alfred -
Alfred NESWADBA
Message 12 of 16
lejochan
hi
no i am on windows 8
Message 13 of 16
Alfred.NESWADBA
strange, I guess there is a lot of things to test now, but that needs some knowledge about operating system.
Especially that the service pack installer shows that the basic product is not found makes me thinking that either the installation is defect or the registry is defect (cleaned with cleaning/optimizing tools).
As you are student, download the AutoCAD 2016, install it (inluding SP1) and see if that works then. Your drawings you have created yet are working well with 2016.
Make sure that you download the release instead of installing it directly from Internet. Then login as administrator, turn off antivirus and start the installation from the downloaded file(s).
Good luck, - alfred -
Alfred NESWADBA
Message 14 of 16
lejochan
thank you i will try it and let you know if it is working. do i have to uninstall autocad 2014? can you please send me a link as to where i can download the release.
Message 15 of 16
Alfred.NESWADBA
you don't need to uninstall any previous release, But if you plan to do that then uninstall it before installing the new release (and make sure the uninstall process is a clean one like described >>>here<<<).
Autodesk virtual Agent, to be found >>>here<<<
- alfred -
Alfred NESWADBA
Message 16 of 16
lejochan
thank you very much. it is working. the best
AutoCAD Inside the Factory
