AutoCAD Forum
problem with autocad
4 REPLIES 4
406 Views, 4 Replies
Hello!
I have a question on how to fix red circels in avtocad. The circels appear when i use tool hatch.
I don`t know how to fix this so i would ask for some help pls.
Thank you for ysyour answers.
4 REPLIES 4
leowarren34
Hi @Anonymous,
This is the break/community room, a chilled out, non product specific forum, I'll ask the admin to move this thread to the AutoCAD forum.
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Can you be more specific about your problem?
Submitting a screenshot of the issue may help!
Without knowing any other details, I think your issue is that you are trying to hatch areas that do not have closed boundaries.
2 things to try:
You can adjust the >hpgaptol< system variable to allow for area(s) with openings to be hatched, or:
Better idea is to find the gaps in your geometry and close them.
Sometimes AutoCAD can get "confused" if you zoom in & out when you are working on hatching, and "think" that there is a gap when there really isn't. In this case, regen or regenall command should make the red circles go away and allow you to hatch your desired boundary.
Hope this helps.
S.Faris
Make sure the area you are trying to hatch is a closed one.
To make this sure, FILLET(radius=0) all the joints/corners, especially the corners/joints where the red circle was shown.
This will help to close any unnoticed gaps.The Hatch command should work for after this.
SALMANUL FARIS
AutoCAD Inside the Factory
