AutoCAD Forum
Problem with a specific autocad file
22 REPLIES 22
Message 1 of 23
emma.latisK6GHM
1602 Views, 22 Replies
I have a problem with a specific autocad file.
I have been working on this file for months and it has never given me any problems. Lately every time I work on it after some time autocad stops unexpectedly sometimes saying "Fatal Error".
This thing only happens to me with this specific file.
I tried to follow the advice of autodesk to solve the problems of damaged or low performance designs but nothing has changed.
I also tried to uninstall all autodesk and autocad and install it again but nothing has changed.
How can I do without losing the drawing and being able to continue working on it?
22 REPLIES 22
Message 21 of 23
I tried to open this test file that you had attached to me in the re-installed autocad, after having done the clean-uninstal procedure yesterday, but it didn't work again. The program stops
Message 22 of 23
emma.latisK6GHM
in reply to: pendean
I also tried to open these two files that you had attached me in the reinstalled autocad, after performing the clean-uninstal procedure yesterday, but it didn't work again with both the two files. The program stops after 10 minutes on each file
Message 23 of 23
@emma.latisK6GHM wrote:
... my work partner who has managed in these days to go on working on the file without problems on a Mac computer. I opened the file on my computer and after about 10 minutes the program stopped again.
This sounds like you have a problem with your computer.
Did you a google search for "e0434352h"? You will find some suggestions - the most helpful seems to be: reinstall the .net Framework (read the posts).
Jürgen Palme
AutoCAD Inside the Factory
