Problem using Revolve command on Z axis
Hello, i having a issued and need some help,
I'm trying to revolve this piece on the Z axis
and make it something just like this pic,
but for some reason its unable.
I've never have this problem before and now i do, can someone help me out please?
Thanks.
imadHabash
click on below image and see if LOFT or Extrude commands can solve your issue .
Imad Habash
blandb
Your profile is over the axis you are trying to revolve around. It can be collinear, or open but not past.
Autodesk Certified Professional
thx for the help.
but i want it to lock like this
eligar_14_0-1603907477866.pngScreenshot 2020-10-28 125730.jpgScreenshot 2020-10-28 125621.jpg
the piece is not flat .
imadHabash
click on below image and try REVOLVE command after drawing an elevation for your revolved object .
Imad Habash
blandb
Correct, @imadHabash said. Either select what to revolve about, or if you want to use a specific axis, make sure you dont overlap the axis.
