AutoCAD Forum
problem plot to pdf line go ghost
7 REPLIES 7
Message 1 of 8
888 Views, 7 Replies
i have made a isometrick drawing of a central heating system in difrent layers.
but when i plot it most of the lines just become ghost like half transparant.
i have tried all plotting styles mono acad and all.
how could this come?
below a picture of how the plot came out any idea's?
7 REPLIES 7
Message 2 of 8
pendean
pendean
Community Legend
Community Legend
Show us your DWG file.
Message 3 of 8
in reply to: pendean
here you go i have found out that it happens when the size of the ploting paper gets bigger how bigger the size the more lines go ghost
Message 4 of 8
pendean
pendean
Community Legend
Community Legend
plotting to what? a thin line gets thinner on a larger scale... .
Do you need color too? Apparently you do, but you make no effort to create any line weights in your line drawing that I can see.
Do you use plot style table? Apparently not in your sample.
See PDFs attached with various lineweights printed to a large paper size, zoom in to see them if your PDF viewer settings don't show it. I used a plot style to set line weights for each.
Message 5 of 8
i wanted to plot to a iso A1 format.
no i didn't add any weight to my lines because some lines are totaly fine and others weren't,
i used most of the plot table's and in my previeuw everything is fine only not in the pdf file that is created.
yes i indeed needed colour but the problem was there too when i used monogroom or grayscale
Message 6 of 8
setting most resently used
Message 7 of 8
pendean
pendean
Community Legend
Community Legend
Make this change
To get this preview
See PDF and DWG file.
Make this change
To get this preview
Message 8 of 8
oke thank you the problem is solved now
AutoCAD Inside the Factory
