Always that I install them together (same pc), Civil3D delete the Autocad-vanilla-option to "reset to default". Then I need Uninstall Civil3D and reinstall Autocad Vanilla
How can I install together Civil3D and Autocad Vanilla without generating such a problem?
PD: Same problem happens in multiple devices that I have like laptops and pcs.
Solved by Alfred.NESWADBA. Go to Solution.
you can create your own icon for resetting an AutoCAD based product by changing the reset item you see by using right-click and properties and change the /product parameter as shown here:
- alfred -
- alfred -
thanks for help.
