AutoCAD Forum
problem installation AutoCAD 2016
16 REPLIES 16
Message 1 of 17
vanekalajdziev
3252 Views, 16 Replies
When I started instalation AutoCAD 2016 then is appeared: AutoCad 2016 is not found on this computer. You will need to install AutoCAD 2016 to install this product specific pack. What to do to resolve this problem?
16 REPLIES 16
Message 2 of 17
pendean
in reply to: vanekalajdziev
So which bundle package did you purchase?
Message 3 of 17
vanekalajdziev
in reply to: pendean
AutoCAD 2016 student version (free softwere) from Autodesk
Message 4 of 17
pendean
Us the Browser Download option, get the 1.5+Gig file on your PC, then double-click on that file to install it.
Message 5 of 17
vanekalajdziev
It doesn't work, after double click on lanched aplication AutoCAD 2016, it won't exract to destination folder. What to do now?
Message 6 of 17
JDMather
Post screen shots of EXACTLY what you are trying to install.
It sounds like you are trying to install a Hotfix, not the AutoCAD software.
You should have this file downloaded when using Browser Download.
What is the EXACT url you are going to to download AutoCAD?
Message 7 of 17
vanekalajdziev
in reply to: JDMather
Message 8 of 17
JDMather
Unfortunately I do not see the size of the download in any of your images.
That would be the only way I would be able to have an indication if the download was successful.
Also,
System specs.  What is your OS?
Assuming the file size is correct - I would try moving to C:\ and extracting from there rather than D:\
I would probably temporarily disable UAC and anti-virus as well.
You never did specify the url of where you got the file, I assume it was an legitimate Autodesk site, but...
Message 9 of 17
vanekalajdziev
Edited by
Discussion_Admin
Message 10 of 17
JDMather
No, no, no, noooooooooooooooooooooooooooooooooooooooooo.
Don't ever post your personal Serial Number in a public forum - it has probably already been stolen by now.
Why are you downloading again?
Why are you showing a screenshot of download in progress?
Why did you use a camera to take a screenshot?
I simply wanted to know the file size of your previous download.
You can use the Windows Snipping tool to capture screen shots or simply hit Print Screen to capture to clipboard and then paste in to Paint.
Does your school have a Student IT Help Desk that can help you install software?
What about an experienced classmate?
What about your instructor?
Message 11 of 17
vanekalajdziev
what is this? how to resolve it? what to do?
Message 12 of 17
vanekalajdziev
Message 13 of 17
JDMather
You are asking your questions in the wrong forum - you should post your questions over here http://forums.autodesk.com/t5/installation-licensing/bd-p/24
Message 14 of 17
pendean
Do NOT use the INSTALL NOW option: either use the Browser Download option or the Download Now option to copy the installation file to your PC. Then double-click on that file to start the installation.
Or get your 2016 installation file from here (Download Link): http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
Message 15 of 17
I had your same problem. Fortunately I found the solution. The explanation is in Spanish. Regards. http://autode.sk/1LDolFA
If you want an explanation in English, let me know. Smiley Happy
Message 16 of 17
i have the same probleme
Message 17 of 17
JDMather
Autodesk Virtual Agent (Google)
AutoCAD Inside the Factory
