Problem in window command (Plot)
There's a problem when I'm plotting. When I click on  "window" I can't zoom or make any movement. All the viewports lost their position and I need press Enter a couple times to back on plot configuration screen.
In attachment is the image showing how the problems happen.
Thanks since now,
Best Regards,
Gabriel
rkmcswain
This is a known issue AFAIK.
Do you have all of the service packs installed?
See also:
https://knowledge.autodesk.com/support/autocad-civil-3d/troubleshooting/caas/sfdcarticles/sfdcarticl...
Secondary to that, if you are printing from a layout, why would you ever need to pick a window?
