INSERT command has blocks that I cannot get rid of
BVPE
Message 1 of 15
BVPE
Using the insert command to insert a block, the list of blocks contains many blocks that I want to delete.  How can these unwanted blocks be deleted.  Purge command is not doing it.
Replies (14)
Message 2 of 15
Sofia.Xanthopoulou
Hi @BVPE,
usually "purge" cleans all unused blocks. That means, your blocks are used somewhere on the drawing. Even if the have no content. Is it possible for you to upload the drawing and tell me which blocks you want to purge. I will take look on this.
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Message 3 of 15
BVPE
Attached is a drawing.  I want to get rid of the numerous blocks that are architectural blocks that include appliances and cabinets or casework.  Once I know how to eliminate these unwanted blocks I can clean them up as I need.
BVPE
Message 4 of 15
pendean
Community Legend
Community Legend
Nothing attached.
Message 5 of 15
BVPE
I added the file in the attachments section.
Message 6 of 15
Go to insert, block, you will see many blocks that I want to get rid of.
Sent from a mobile device.
Message 7 of 15
pendean
Community Legend
Community Legend
Which one is the actual block or entities that you want? Your file opens with nothing visible.
otherwise DXFOUT then DXFIN to a new file gets rid of almost everything.
Message 8 of 15
Sofia.Xanthopoulou
Hi @BVPE,
as @pendean said... this drawing is empty with only those blocks. I hope I understood you correctly that you want to get rid of all of them.
Another easy way to clean up drawings would be "wblock". At the end there are two blocks left, which I believe belong to dimension styles.
Would this be ok for you, or are there only specific blocks you want to get rid of?
Talk to us Smiley Happy
Regards
Message 9 of 15
TheCADnoob
From what i understand these are left in there from the verticles. The drawing actualy isnt empty, there is one block in there, but deleting it doesnt help. if you select all Ctrl+A and brin up properties window you can see its a block.
I was able to get rid of most of it doing an EXPORTTOACAD2013
I tried to WBLOCK but it had limited success as well
CADnoob
Message 10 of 15
BVPE
What do you mean by wblock?  How does this command delete those blocks that are displayed in the dialogue box for Insert, Block name dialogue box?
Message 11 of 15
Sofia.Xanthopoulou
When you click on the word "wblock" in my thread you will see a screencast how this command works. It will purge all unnecessary items in the drawing.
You can also check out the AKN article on wblocks.
Regards
Message 12 of 15
BVPE
Thanks that worked.
Message 13 of 15
Sofia.Xanthopoulou
Hi @BVPE,
I am glad, that worked out for you Smiley Happy.
Could you do me one favour - the marked thread is not actually the solution Smiley Wink Can you please unmark this and mark the post that you consider solved your issue.
Thanks a lot.
Regards
Message 14 of 15
BVPE
The solution that you provided got rid of the unwanted blocks.  However, it deleted layers that I did not want deleted.  How can I not delete layers and still get rid of the unwanted blocks?
Thanks.
Message 15 of 15
Sofia.Xanthopoulou
Well, once you have the "clean" drawing, you could use the design center to drag and drop all needed objects/styles into your drawing from the original one.
The other question is, why do you insist to use this drawing? Take a new template and drag and drop only what you need. Wouldn't that work as well?
Regards
