Problem autoCAD dimentions
Hello Everyone,
In attachment I have 2 pictures. You can see that I selected in each picture one line. These 2 lines are standing next to each other and they are also having the same layer. The problem I have is that 1 line is 2.85 long while the other is 33.3721. Also if i use the measure tool, the first line is 2.85 while the other is 33.3721. What am I doing wrong. I tried to delete it, also tried to start over. But after a time one of the dimension's isn't correct. Probably I'm doing something wrong? I tried google but could't find anything. I hope someone can help me. Thank you for the answers.
Raf
JDMather
2D right?
Then why does one of them have a Z coordinate on one end much different than the Z coordinate on the other end?
Rotate in 3D a bit and you  will clearly see the problem.
The line endpoints are not all at the same elevation.
JDMather
Examine the attached.
Hello JDmather,
You are right. This will be the problem. I changed the working angle because the left side of this project is placed in an angle. I used the USC tool. Probably I did something wrong. Do you know what the best thing is to solve this problem? I mean can I use a simple tool?
Thanks you for the fast respons!
Raf
Edit: Found the solution. Just by editing the Z coordinates. Th!
