Export Volume of 3D to txt file
michalb1993
Observer Observer
michalb1993
Observer
Observer
Hello
I have such problem, I have a 3D Solids shapes, not just one, houndreds of them. I want to use a command to export volume of those 3D solid shapes to txt file.
I have found for now only one method to export volume of those shapes to txt, its _MASSPROP command, i have to make this command to every single shape because if I will select several objects it will return me a combined volume of those object, it's really not productive.
I think the only method to do it quickly is lisp routine. Does anyone know sometihng about such Lisp routine?
Michał
john.vellek
Hi @michalb1993,
MASSPROP is the correct command for ywhat you are trying to capture but I think you are correct that a LISP program is likely necessary to break down the totals by entity. I will move this to the customization forum so you can get better solutions from the community.
John Vellek
