Problem Attach PDF
rimutaka
Problem Attach PDF
rimutaka
Hi, I used to attach PDF into drawing without any problem. But now I have problem to attach it. I am using AutoCAD 2015. Can someone explain to me ?
Alfred.NESWADBA
And the problem is ....?
Please recognize that we are not sitting besides of you, we have not seen what you do, what AutoCAD then did and what you see. Without that information's we can't support you.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
imadHabash
Would you please present your problem with more info?
Imad Habash
rimutaka
Hi, These are the steps I always do: 1. Open the drawing where I want to insert PDF 2. Go to Insert menu -->> Reference -->> Attach 3. Browse to file to find a pdf and click open 4. A window "Attach PDF Underlay" is open 5. Choose settings and click OK 6. click insertion point in the drawing 7. Adjust scale factor 8. Finish Hopefully above information help.
rimutaka
Hi All, Problem solved!!. This morning, just open drawing and carry out the steps I mentioned above........and it works. Thanks
dmldml
I go through the step up to "insert" ; when I click on 'insert' i get message " missing or invalid reference"   I selected the pdf in the file where it resides, so I don't understand how it is either missing or invalid  (?!)
cadffm
I don't understand: You want to ATTACH a pdf, and you say you select the pdf what is already present?
That doesn't make sense, so I guess you try to IMPORT a pdf, what means you want to convert the pdf content to autocad object (what is attached to th file already), right?
This means you want to convert the pdf content to autocad objects.
Tell us in detail what you have now and whats your goal.
Screenshots welcome too (or dwg and pdf files).
Sebastian
