Multicore processors (MORE 2 cores)
Message 1 of 34
Hi, I'd like to know if you're going to optimize AutoCAD with multicore processors to use all available resources because AutoCAD is a poor performer when it comes to using the computing power provided by modern processors (example: Double Intel Xeon Quad core = 16 logical processors) while most cheaper pro software do better.
Thank you
Sebastien
Replies (33)
Message 2 of 34
Shrestl
Welcome to the Autodesk Community, and thank you for posting your question here in the AutoCAD forum!
AutoCAD supports multi-core technology only in specific areas of the product and typically set to only using 2 of the processors. It uses 100% of the resources of a single-core processor and uses a maximum of 50% of the CPU for that same operation on a dual-core computer, and only 6% of each CPU on a 16-core computer.
With that said if you use the command WHIPTHREAD which by default set to 1 which is 'Regeneration multithreaded processing only; regeneration processing is distributed across two processors on a multiprocessor machine' selection.  You can change the setting to 2 or 3 if you want.
Just remember, when multithreaded processing is used for redraw operations (value 2 or 3), the order of objects specified with the DRAWORDER command is not guaranteed to be preserved for display, but is preserved for plotting.
For more on this please look at the knowledge articles:
WHIPTHREAD (System Variable)
Support for multi-core processors with AutoCAD / AutoCAD for Mac
Laura.Shrestha
Public Technical Support Specialist
Community FAQ | Community Feedback | Product Feedback | Support & Learning
Message 3 of 34
I am familiar with the WHIPTHREAD command, but today there are no longer mono-core processors and use 2 hearts only it is very little, we are in 2019, I expect better performance of a pro software of this price. The majority of processors aim for massively multi-threaded use with a lower clock rate. Open source software uses all the available cores for exceptional performance. Will Autodesk follow or not?
Thank you
Sebastien
Message 4 of 34
Shrestl
A good question Sabastian I am going to add @VinodBalasubramanian in to answer this for you.
Laura.Shrestha
Message 5 of 34
dan908
AutoCAD takes advantage of multi-core where there is a benefit. But, for the most part, splitting apart a pan operation or zoom operation would not make it faster. Hatch takes advantage of multi-threading, most 3d operations take advantage, but a lot of things are slowed down by it. We do push those operations out to the GPU for better performance in graphics regen and display so having a fast video card will benefit you.
We do continue to research areas where multi-threading makes sense also. I know in the update for 2020 there is a setting GSTHREADING that you can change to 0 if you want to see some of the newest improvements (but please note that you may also see some errors in some AutoCAD products turning it on). If you want to check out the latest threading improvements (and this is mainly 3d) try it out for a few hours and feel free to provide feedback here.
Dan
AutoCAD Quality Assurance Manager
Message 6 of 34
Unknown command "GSTHREADING". Press F1 for help.
I am on AutoCAD 2020, this command does not seem to exist.
I started using AutoCAD from version 14, then 2000, 2000i, and so on. and AutoCAD is getting slower from one version to another. I have a dual Intel Xeon E5520 2.26GHz quad core, 12GB DDR3 ECC RAM memory and a Nvidia Quadro NVS 420 graphics card (it's a Dell Precision certified for Autodesk products when it's purchased) that is powerful for all my applications except AutoCAD. AutoCAD 2018 is ok, 2019 is slower and with 2020 even slower.
Sebastien
Message 7 of 34
Shrestl
That might be because of a few things:
  • How old are your user settings? Some settings older than 2018 seem to not play nice with the new way AutoCAD runs.  So if you are running 2017+ settings they were created in a different file format than 2018+.
  • Are your files located not on your C drive?  If they are not in the default search paths under options than I would suggest you add those search paths by going to Options>Supported File Search Path>Add and then Browse to where the files you work in are saved.
  • I would also suggest you check your GRAPHICSCONFIG and make sure you are pointed at the right graphics card and that it is up to date.  If its using a lower ended graphics card than close AutoCAD and right click on the AutoCAD icon and select 'Run on higher end graphics card'.
Laura.Shrestha
Message 8 of 34
dan908
The GSTHREADING setting is only available with the Update 1 for 2020. You can download it from your manage.autodesk.com account. It is off by default because it is still a newer item that we are testing out, but it sounds like you are interested in it so I wanted to get you the latest on it. But, yes, so new it is only available in the update that came out in early August.
Dan
Message 9 of 34
I use a clean install AutoCAD 2020 with a clean install Windows 10 pro.
"""If its using a lower ended graphics card than close AutoCAD and right click on the AutoCAD icon and select 'Run on higher end graphics card'.""" I don't have this option on my Windows 10
My computer is old but still very powerful for all other applications, I think it's all the programming AutoCAD is to review and reinvent. The early version of the early 2000s was much faster. Now I am obliged to choose a computer with the only criterion a processor with a very high frequency, 3.5GHz to 4GHz see 5 GHz ditto for the graphics card because from year to year AutoCAD become more and more heavy (Bloatware ).
Sebastien
Message 10 of 34
Shrestl
Would you like me to escalate your issue into a case so we can do a deeper dive into your issue you are experiencing?  I would be more than happy to.
Laura.Shrestha
Message 11 of 34
Yes
Thank you
Message 12 of 34
Tiggz1
Interesting comment 'How old are your user settings?'
I typically migrate settings from one release to the next.
How can we clean up the older migrated settings? Or do we need to do a new install without migrating settings from older versions?
Message 13 of 34
Alfred.NESWADBA
Changing to 0 may show errors? Then please do not use that as default as my AutoCAD has that variable set to 0
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 14 of 34
Alfred.NESWADBA
>> WHIPTHREAD [...]
Values 2 and 3 are defined as obsolete in the help >>>click<<<
Where is the mistake?
- alfred -
Alfred NESWADBA
Message 15 of 34
dan908
Sorry, yes, typo. 0 off and 1 on. Default off. The impact right now is mainly if you have Advance Steel objects in your drawing. But, for now it is usable for testing out only.
Dan
Message 16 of 34
dgorsman
Sebastien
What other software are you comparingbto?
For reference, I haven't seen a slowdown over multiple versions, despite doing more with each.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 17 of 34
AllenJessup
@Shrestl
Is there any documentation on GSTHREADING?
Allen Jessup
CAD Manager - Designer
Message 18 of 34
Shrestl
Message 19 of 34
AllenJessup
Thank you. However there are no mentions of GSTHREADING in those articles. I've known of WHIPTHREAD since it was introduced. There is also:
Allen Jessup
Message 20 of 34
dan908
There is not documentation on GSTHREADING setting - it is currently only a testable feature. We have gotten a lot of feedback on it though and feel free to let us know if you have additional feedback (on this thread is fine).
Dan
