I am trying to print drawings to scale with my model space units in M. the only way in can get my drawings to print off to scale is by converting them to mm by increasing the scale by 1000x. is there any way thta i can leave my drawings in metres and be able to print to scale. i am using autocad lt.
Perhaps the plotting dialogue box does not give unambiguous assistance when trying to set it up.
If you go to the area that says Plot scale, then it you choose custom scale you then can fill in figures. Remember that AutoCAD uses mm in metric mode.
So the first space to fill in has the units mm default. Just scroll down until you find m. If you can't find m, then change the 1 to 1000. Then the next space is for units, so you put in your chosen scale, for example 250 for plotting at 1 to 250.
If you are plotting without a drawing frame, then choose the area to plot by window, and check the centre the plot button. Always do a full preview to see whether you have got it right.
