Dear all, I have made few specific layers with specific colour and lineweight to use in my drawing. I want to know how to keep the lineweight appearance in printing same as I mentioned in my layer if different lines using same layer but different colour.
I have given here an example for your clear understanding. Please help.
Solved by S.Faris. Go to Solution.
Change the Lineweight inside the plotstyle editor to "USE OBJECT LINEWEIGHT" for the required colors(or all colors if you want the Object line weight to be prioritized for all colors)
SALMANUL FARIS
You can select the lines you want to be a different color and assign said color through properties pallet. Use a true color if you want to override your plot style and have the lines plot in color. See attached screenshot.
