Preview does not match paper space or actual plot. Logo image is distorted in preview only.
apWVKRW
apWVKRW
Hi, I am creating a new title block starting with my company's logo.
I have placed it correctly, but it is distorted in the preview. I want to fix this as I want a nice clean template. It prints correctly, just the preview is distorted...
Weird thing is if I move the logo to the middle, the preview works correctly.
illusionistNUGXG
Hmmm...
I would recommend to draw the logo in AutoCAD (including the text) and put it into a block.
Takes a little bit of time, but this guarantees you a clean template.
You can then also use the logo for other purposes in bigger size, without getting it blurry.
(Best way would be using closed polylines with thin line weights and fill them with solid hatches)
pendean
Community Legend
Community Legend
So this is only a PREVIEW concern? Yes?
No one here can fix that. I see your logo moved?
Took a stab at guessing where it should be
 Output seems fine.
