AutoCAD Forum
Prevent Text Mirroring in a block
9 REPLIES 9
Message 1 of 10
MikeKovacik4928
34295 Views, 9 Replies
MikeKovacik4928
I seem to remember, as do some other draughtsmen in this drawing office,
when you could mirror a block with text in, and the text wouldn't get mirrored.
Was that the case?
You can't do that now, that I know of, the text always get mirrored, mirrtext 0 or 1
Mirrtext works with individual text entites, but not with blocks.
Is there a way of getting the text in blocks not to mirror?
It would be very useful!!
Right now I am having to rotate my block and then reposition it.
I can do that, since my block is symmetrical.
If my block was not symmetrical I wouldn't be able to do this,
but would have to create a second block of the same thing, with the
outline of the block mirrored and the text reinserted again.
Michael Kovacik
AutoCAD 2d & 3d (29 yrs)& Inventor (7 yrs)
Manufacturing (30 yrs) Draughtsman
Autodesk Product Design Suite Ultimate 2018
Johannesburg, South Africa
Was that the case?
Michael Kovacik
9 REPLIES 9
Message 2 of 10
vladimir_michl
It is not just the MIRRTEXT - see the many options for text mirroring in blocks (inc. dynamic blocks):
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=6251
Vladimir Michl, www.cadstudio.cz  www.cadforum.cz
Message 3 of 10
3wood
in reply to: MikeKovacik4928
3wood
You need use ATTRIBUTE instead of simple TEXT object inside a block to allow it ignoring mirroring of the block.
Message 4 of 10
pendean
pendean
Community Legend
Community Legend
ATTRIBUTES, not TEXT, in blocks do what you want.
By using text you are basically locking that in so it stops having any intelligence and will ignore variables settings. Change your text to attributes and see for yourself.
Message 5 of 10
MikeKovacik4928
in reply to: 3wood
MikeKovacik4928
okay
now I have solved the text mirroring problem.by using attributes instead,
I can't do a background mask on an attribute like I did on the text.
See attached.
Is there any way of doing this, without  having to do a complicated
"wipeout" setup
Michael Kovacik
okay
See attached.
"wipeout" setup
Michael Kovacik
Message 6 of 10
Mike wrote:
okay
See attached.
"wipeout" setup
Mike,
Here is how I do provide background masking on attributes. Open your block in the "Block Editor". Select the attribute, and select "Properties".  Go down to "multiple Lines" and select "Yes". You now have Mtext. Double-click on the Mtext and you will see a smal editing box. Select it, and it will open an Mtext box. You make now make a "background mask".
Good luck,
Mike wrote:
okay
See attached.
"wipeout" setup
Mike,
Good luck,
Message 7 of 10
JoshuamRivera
attdef or mirrtext neither work. once you add the text attribute inside the block it dissapears.
Message 8 of 10
minhha_nguyenWSPTS
you need to first sync attribute with attsync and it will appear. However my attribute still got mirrored
Message 9 of 10
mgosselin_solutionmig
Community Visitor
Community Visitor
I found out that if you have a block with text in it and you add a dynamic flip inside your block and you select all your objects including texts and dimensions : then the text will stay readable after the flip.
I hope this can be useful to someone.
Message 10 of 10
biolightant
Community Visitor
Community Visitor
Merhaba VBA ile bulduğum çözüm.
Option Explicit
Sub TextInsideMirroredBlock()
' Biolight 2024 - Eppur Si Muove - biolightant@gmail.com
' Block içinde yazı varsa (Text, Dimension a bağlı text)
' MIRRTEXT = 0 olmasına rağmen
' Block Mirror (aynalama) yapılınca yazılar TERSTEN gözükür
' Bu hatayı gidermek için bir çözüm üretir
    Dim objEnt As AcadObject
    Dim emptyPt(0 To 2) As Double
    Dim point1, point2 As Variant
    On Error Resume Next
TekrarSec:
    ThisDrawing.Utility.GetEntity objEnt, emptyPt, "Düzenlenecek Block seçiniz: "
    If Err <> 0 Then
        ' esc, space veya enter tıklanırsa sonlandır
        If CInt(ThisDrawing.GetVariable("ERRNO")) = 52 Then
            ThisDrawing.SendCommand Chr(3)
            Err.Clear
            Exit Sub
        Else
            ThisDrawing.Utility.Prompt "Block değil...!" & vbCrLf
            Err.Clear
            GoTo TekrarSec
        End If
    End If
    If objEnt.ObjectName = "AcDbBlockReference" Then
    ' MIRRTEXT değişkenini 0 olarak ayarla
    ThisDrawing.SetVariable "MIRRTEXT", 0
    ' Block un kapladığı alan koordinatları
    objEnt.GetBoundingBox point1, point2
    objEnt.Explode ' Blok u patlat ( MIRRTEXT=0 dan dolayı yazılar düzeldi ama block parçalandı )
    objEnt.Delete ' Mevcut bloğu sil
    ' Group u oluşturacak objeler : Patlatılan block un kapladığı alan koordinatları için de
    ' Crossing ile bu alanı belirle ve objeleri seç ( x.x,y.y,z.z )
    ThisDrawing.SendCommand "GROUP CROSSING" & vbCr & _
    Replace(point1(0), ",", ".") & "," & Replace(point1(1), ",", ".") & ",0.0" & vbCr & _
    Replace(point2(0), ",", ".") & "," & Replace(point2(1), ",", ".") & ",0.0" & vbCr & vbCr
    ThisDrawing.Utility.Prompt "Yeni bir " ' TekrarSec ile "Yeni bir Düzenlenecek Block seçiniz: " gözükecek
    Else
        Err.Clear
        GoTo TekrarSec
    End If
GoTo TekrarSec
End Sub
Option Explicit
TekrarSec:
    If Err <> 0 Then
            Err.Clear
            Exit Sub
        Else
            Err.Clear
            GoTo TekrarSec
        End If
    End If
    Else
        Err.Clear
        GoTo TekrarSec
    End If
GoTo TekrarSec
End Sub
AutoCAD Inside the Factory
