Presspull command does not select lines?
My Presspull command stopped selecting lines.
How can I fix this?
Thank you for your help.
john.vellek
HI bruce4444,
Presspull can be pretty picky sometimes! If it can't find a clean, closed boundary it just won't pick anything at all. Instead of hoping that it can detect a boundary you can try creating a polyline boundary first and then selecting the boundary.
Trying to minimize the number of entities on the screen can also help. Try freezing items that are not necessary and zooming in tight to the whole are that you want to work on.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
JOHNLLOYD7213
I've found the press-pull command to be very unreliable - especially if a solid has been sliced previously.
Some times it just refuses to select certain faces.
IMHO, this cheesy command should be abandoned & the stretch command should be expanded to work in 3D just like it does in 2D.
Having two commands that effectively do the same thing is counterintuitive & must be very confusing to newbies.
Then again, what do I know? I'm not a clever programmer, I'm just a dumb draffie.
john.vellek
HI bruce4444,
I am checking back to see if my post helped you with your problem. Please add a post with your results so other Forum users can benefit.
John Vellek
ensuring all boundaries are closed has helped me
