Positioning text angular
Scary99
Scary99
I am a recent graduate of Autocad courses at a community college.  I just started working and need to position text along angular object lines ( imagine the spokes of a wheel).  I only learned how to position text horizontal or vertical in school. I do ask questions of the experienced techs but I do want and need to solve issues on my own. Suggestions please.
@Scary99
You can try this:    ARCTEXT (Express Tool)
imadHabash
HI,
you can do it by many ways , here is some :
  • select your Text then press and hold Ctrl+1 . change Rotation angle . ( see below image )
  • OR change your UCS >> OBject ( select oblique existing line ) to match the line angle . and to get back to normal position UCS >> World .
Imad Habash
Kent1Cooper
There's no need to change the UCS or to make the Text first and then change its rotation angle in Properties.  There is a prompt for the rotation angle in the Text command itself:
Command: TEXT
Current text style:  "Standard"  Text height:  0'-1"  Annotative:  No  Justify:  Left
Specify start point of text or [Justify/Style]: j Enter an option [Left/Center/Right/Align/Middle/Fit/TL/TC/TR/ML/MC/MR/BL/BC/BR]: MC
Specify middle point of text: {picked a point}
Specify height <0'-1">: 2
Specify rotation angle of text <0d0'0.00">: 30
Are you not  getting that prompt?  You can OSNAP to locations on drawn objects [such as the MIDpoint and an ENDpoint of your angled Lines] for both the insertion point and to define the rotation angle -- you don't need to type in  an angle value as in the above excerpt.
And if you're talking about Mtext rather than Text, after you give it a corner point, there an option for setting the rotation, which you can also set by Osnapping to align with existing drawn objects:
Command: MTEXT
Current text style:  "Standard"  Text height:  2"  Annotative:  No
Specify first corner:
Specify opposite corner or [Height/Justify/Line spacing/Rotation/Style/Width/Columns]:
Kent Cooper, AIA
GrantsPirate
I too like to rotate the UCS for this and lots of other uses.  Lots of ways to do the same thing in AutoCAD.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
imadHabash
Yes .. you're right . Rotating ucs and Proprieties palette always give us a great manipulate options to solve CAD issues . 🙂
Imad Habash
