unable to save DWG TO DXF
Sans titre.pngje suis un nouveaux membre et c'est mon premier post
sur la photos il y a les choix DXF et aussi le message afficher après l’enregistrement
@Anonymous
Try running the AUDIT command on the drawing to see if Acad finds anything wrong.
If it does not work try this Error: "Cannot save the drawing [path/filename].dwg..."
cadffm
EDIT - Oh, now i saw you tried to store local in a path wirhout special characters.. sorry, that really another problem. - EDIT
Saveas DXF to local folder, is it working?
Then
I think you have special characters in your path and your network storage use a unix filesystem.
Sebastian
thank you
but when i try to open this on CBS "format de fichier inattendu"
what's wrong
